Here you go, best I haveI'm building a car from scratch. Right now it is still on paper and one thing holding me up is the exterior measurements of the 4bt. Once I have those I can tweak the design and start welding. The car will basically be a beefed up lotus 7. Any info would help.
Wow Lotus 7's are small & low fitting a 4bt into a beefed up one should be interesting, do you have some drawings you can share?I'm building a car from scratch. Right now it is still on paper and one thing holding me up is the exterior measurements of the 4bt. Once I have those I can tweak the design and start welding. The car will basically be a beefed up lotus 7. Any info would help.
