ENGINE TOPIC INDEX - A thru H
ENGINE TOPICS A thru H:
3B Cummins, 3 Cylinder Diesel Engines:
https://www.4btswaps.com/forum/showthread.php?t=5164
https://www.4btswaps.com/forum/showthread.php?9502-3-cylinder-cummins
https://www.4btswaps.com/forum/showthread.php?38690-N-A-6bt...&p=367666#post367458 <=Pictures
Abbreviation, Engine Designation:
https://www.4btswaps.com/forum/showthread.php?t=4755 <=What does 4BT stand for?
Accessories, Miscellaneous Engine parts, Options, Assorted:
https://www.4btswaps.com/forum/showthread.php?t=1194
https://www.4btswaps.com/forum/showthread.php?t=2879 <=Pictures of common options & accessories
Alcohol, Water Injection:
https://www.4btswaps.com/forum/showthread.php?t=2680
Application; 4BT or 6BT, Before you start converting, Getting Started, Selecting;
Also see "Legal Aspects and Requirements" below ▼:
https://www.4btswaps.com/forum/showthread.php?t=464
https://www.4btswaps.com/forum/showthread.php?t=1103
https://www.4btswaps.com/forum/showthread.php?t=1239
https://www.4btswaps.com/forum/showthread.php?t=1534
https://www.4btswaps.com/forum/showthread.php?t=1937
https://www.4btswaps.com/forum/showthread.php?t=2935 <=Generator set engines, non automotive differences
https://www.4btswaps.com/forum/showthread.php?t=3158 <=4BT or 4BTA?
https://www.4btswaps.com/forum/showthread.php?t=4971 <=Choices between a 4BT or 6BT
Application, 4BT Into an Automobile, Car, Weight, Size, and Highway Safety Issues:
https://www.4btswaps.com/forum/showthread.php?t=1944
https://www.4btswaps.com/forum/showthread.php?t=3440
https://www.4btswaps.com/forum/showthread.php?t=3593
https://www.4btswaps.com/forum/showthread.php?t=3673
https://www.4btswaps.com/forum/showthread.php?t=3705
https://www.4btswaps.com/forum/showthread.php?t=4077
https://www.4btswaps.com/forum/showthread.php?t=5459
https://www.4btswaps.com/forum/showthread.php?t=9133
Application, B Series, Farm & Industrial:
https://www.4btswaps.com/forum/showthread.php?t=3698 <=Case equipment
Application as original equipment by manufacturer for highway service:
https://www.4btswaps.com/forum/showthread.php?13485-4Bt-Application
Availability - New and Rebuilt:
https://www.4btswaps.com/forum/showthread.php?t=44
Air Coolers, CAC:
https://www.4btswaps.com/forum/showthread.php?t=139
https://www.4btswaps.com/forum/showthread.php?t=202
https://www.4btswaps.com/forum/showthread.php?t=393
https://www.4btswaps.com/forum/showthread.php?t=428
https://www.4btswaps.com/forum/showthread.php?t=415
https://www.4btswaps.com/forum/showthread.php?t=615
https://www.4btswaps.com/forum/showthread.php?t=681 <=JWAC ?'s
https://www.4btswaps.com/forum/showthread.php?t=965
https://www.4btswaps.com/forum/showthread.php?t=1282
https://www.4btswaps.com/forum/showthread.php?t=1474 <=CAC part numbers
https://www.4btswaps.com/forum/showthread.php?t=1836 <=CAC Piping
https://www.4btswaps.com/forum/showthread.php?t=2285 <=CAC Sources
https://www.4btswaps.com/forum/showthread.php?t=2609
https://www.4btswaps.com/forum/showthread.php?t=3358 <=CAC location placement
https://www.4btswaps.com/forum/showthread.php?15276 <=Sizes, Dodge & others
https://www.4btswaps.com/forum/showthread.php?16805 <=EZ way to put a bead on tubing
https://www.4btswaps.com/forum/showthread.php?14824 Adding a Charge Air Cooler
Balancer, Engine, Counter balancer, Internal rotating type:
https://www.4btswaps.com/forum/showthread.php?t=1787
https://www.4btswaps.com/forum/showthread.php?13744
Balancer, Harmonic:
See "Dampener" below ▼
Balancing Engine:
https://www.4btswaps.com/forum/showthread.php?t=1549
Barring Tool Front Pulley Home Made:
https://www.4btswaps.com/forum/showthread.php?56882
Belt, Tensioner and Mounting Bracket:
https://www.4btswaps.com/forum/showthread.php?t=1390 <=Pictures
https://www.4btswaps.com/forum/showthread.php?t=1418 <=Belt slipping on alternator, pictures, NAPA Replacement Tensioner part number
https://www.4btswaps.com/forum/showthread.php?t=1682 <=Tensioner, amount of movement
https://www.4btswaps.com/forum/showthread.php?t=2412 <=Noisy
https://www.4btswaps.com/forum/showthread.php?t=4628 <=Cross references
https://www.4btswaps.com/forum/showthread.php?15767 <=Serpentine belt size
Block, Engine:
https://www.4btswaps.com/forum/showthread.php?t=2708 <=Bellhousing rear mounting pattern, adapters
https://www.4btswaps.com/forum/showthread.php?t=4063 <=Broken, repairing
https://www.4btswaps.com/forum/showthread.php?p=33714 <=Rust in cylinders & stuck
https://www.4btswaps.com/forum/showthread.php?51130 <=China Aluminum 4bt block
Block Heater, Engine:
https://www.4btswaps.com/forum/showthread.php?t=2092 <=Removal & replacement
Also see "Coolant" section below ▼
https://www.4btswaps.com/forum/showthread.php?p=55531
Blow by test:
https://www.4btswaps.com/forum/showthread.php?t=2192
Blueprint Type Drawing, Measurements, Dimensions, Size:
https://www.4btswaps.com/forum/showthread.php?t=2532
Bolts, Nuts, Fasteners, Metric, Replacement Sources:
https://www.4btswaps.com/forum/showthread.php?t=2141
Boost Gauge:
https://www.4btswaps.com/forum/showthread.php?t=4363 <=Where to install on engine
Camshaft:
https://www.4btswaps.com/forum/showthread.php?t=592
https://www.4btswaps.com/forum/showthread.php?t=1382 <=Broken camshaft
https://www.4btswaps.com/forum/showthread.php?14229 <=4BT-cam-sensor-holder
https://www.4btswaps.com/forum/showthread.php?17151 <=Cam Journals, HOW MANY BEARINGS? Info also in the SERVICE MANUAL
Cold Starting, Cold Climates, Cold Weather:
See "Starting" below ▼
Compression Testing, Compression PSI & Cylinder Differential Specs:
https://www.4btswaps.com/forum/showthread.php?t=509
https://www.4btswaps.com/forum/showthread.php?t=2885
Connecting Rod Bolt Failure Problem:
https://www.4btswaps.com/forum/showthread.php?t=165
Connecting Rod Bearing & Related:
https://www.4btswaps.com/forum/showthread.php?t=8040
Coolant, Anti-corrosion:
https://www.4btswaps.com/forum/showthread.php?t=2719 <=Methods
Coolant Drain, Engine Block:
https://www.4btswaps.com/forum/showthread.php?t=608
Coolant, Heater Hoses:
https://www.4btswaps.com/forum/showthread.php?27379 <=Molded heater hoses
Coolant, Miscellaneous Plumbing Supplies:
https://www.4btswaps.com/forum/showthread.php?14385 <=Source for radiator hose SIZE reducers
Coolant Pump:
https://www.4btswaps.com/forum/showthread.php?t=1538 <=Pump part numbers
Coolant, Radiator, Radiator Hose and Connections, Configurations & Sizes:
https://www.4btswaps.com/forum/showthread.php?t=581
https://www.4btswaps.com/forum/showthread.php?t=971
https://www.4btswaps.com/forum/showthread.php?t=975
https://www.4btswaps.com/forum/showthread.php?t=1690
https://www.4btswaps.com/forum/showthread.php?t=2354
https://www.4btswaps.com/forum/showthread.php?t=2588 <=Radiator size
https://www.4btswaps.com/forum/showthread.php?t=2602 <=Adapting Radiator connections to hoses
https://www.4btswaps.com/forum/showthread.php?t=6277 <=Radiators
https://www.4btswaps.com/forum/showthread.php?t=7382 <=Radiator hose options
Coolant, Block Heater & Expansion Plugs:
https://www.4btswaps.com/forum/showthread.php?t=2788 <=Expansion plugs, freeze plugs, soft plugs
https://www.4btswaps.com/forum/showthread.php?t=2905 <=Powering the block heater & no AC available
https://www.4btswaps.com/forum/showthread.php?t=3176 <=Leak problem
https://www.4btswaps.com/forum/showthread.php?p=55531 <=Block heater pic
https://www.4btswaps.com/forum/showthread.php?t=12071 <=Expansion plug, freeze plugs, soft plugs SIZE
https://www.4btswaps.com/forum/showthread.php?15698 <=Coolant LEAK through BLOCK CYLINDER WALL
Coolant, Oil Contaminated:
https://www.4btswaps.com/forum/showthread.php?t=2240
Coolant Temperature:
https://www.4btswaps.com/forum/showthread.php?t=427
https://www.4btswaps.com/forum/showthread.php?t=9923 <=Overheating
Coolant Temperature Gauges, Sensors & Switches:
https://www.4btswaps.com/forum/showthread.php?t=3471
https://www.4btswaps.com/forum/showthread.php?t=3780
CPL:
https://www.4btswaps.com/forum/showthread.php?t=3200 <=What is "CPL"
https://www.4btswaps.com/forum/showthread.php?t=7255 <=CPL numbers in regard to aftercooling & serial numbers
https://www.4btswaps.com/forum/showthread.php?16187-cpl <=Determining CPL when the tag is missing
Crankcase Breather:
https://www.4btswaps.com/forum/showthread.php?t=11114 <=Filler modification
Crankshaft Bearings:
https://www.4btswaps.com/forum/showthread.php?t=813
https://www.4btswaps.com/forum/showthread.php?t=8342 <=Installing
Crankshaft, Front and Rear Seals:
https://www.4btswaps.com/forum/showthread.php?t=620
https://www.4btswaps.com/forum/showthread.php?t=726
https://www.4btswaps.com/forum/showthread.php?t=882
https://www.4btswaps.com/forum/showthread.php?t=1201
https://www.4btswaps.com/forum/showthread.php?t=2403
https://www.4btswaps.com/forum/showthread.php?t=3289 <=Rear seal part number
https://www.4btswaps.com/forum/showthread.php?t=6621 <=Front seal number
https://www.4btswaps.com/forum/showthread.php?t=7040 <=Rear seal replacement
Crankshaft Spacer:
https://www.4btswaps.com/forum/showthread.php?t=8231 <=How do I remove this? HUB
https://www.4btswaps.com/forum/showthread.php?21587 <=4bt flexplate spacer ring.
Crankshaft Timing Gear:
https://www.4btswaps.com/forum/showthread.php?62170 <=Crank Timing Gear Replacement
Crankshaft, General Information:
https://www.4btswaps.com/forum/showthread.php?t=3154 <=Regrind, Repair, Replace?
Cruise Control:
See "Electrical Section" above
Cylinder Head Bolts,Fasteners, Stud Kits, Nuts:
https://www.4btswaps.com/forum/showthread.php?t=5045
https://www.4btswaps.com/forum/showthread.php?21651 <=Head Bolt Torque Confusion **
Cylinder Head Crack Repairs:
https://www.4btswaps.com/forum/showthread.php?t=135
Cylinder Head Expansion Plugs:
https://www.4btswaps.com/forum/showthread.php?t=3932 <=Soft plug sizes
Cylinder Head Gasket:
https://www.4btswaps.com/forum/showthread.php?t=879
https://www.4btswaps.com/forum/showthread.php?t=1665 <=How difficult
https://www.4btswaps.com/forum/showthread.php?t=1993
Cylinder Head General Information:
https://www.4btswaps.com/forum/showthread.php?t=875 <=Swap to 4 valve head
https://www.4btswaps.com/forum/showthread.php?16937 <=4bt blown head gasket & head studs.
Cylinder Head Swap 16 Valve ISBe to 4BT:
https://www.4btswaps.com/forum/showthread.php?84770-Installing-a-16-Valve-ISBe-Head-on-a-4bt
Cylinder Head Torque Procedure:
https://www.4btswaps.com/forum/showthread.php?t=1157
https://www.4btswaps.com/forum/showthread.php?t=6507
Dampener, Engine mounting, shock absorber style:
https://www.4btswaps.com/forum/showthread.php?t=1616
Dampener, Harmonic Balancers & Pulley:
https://www.4btswaps.com/forum/showthread.php?t=929
https://www.4btswaps.com/forum/showthread.php?t=1243
https://www.4btswaps.com/forum/showthread.php?t=8755 <=Aftermarket questions
https://www.4btswaps.com/forum/showthread.php?t=10428
Dipstick, Tube length, Location Change, Plastic Tube and Mounting:
https://www.4btswaps.com/forum/showthread.php?t=1415
https://www.4btswaps.com/forum/showthread.php?t=1686
https://www.4btswaps.com/forum/showthread.php?t=1859<=Part numbers
Efficiency, Engine, RPM ranges:
See "Mileage"
Emissions Certification Tag:
https://www.4btswaps.com/forum/showthread.php?t=1062
Emissions Requirements:
See "Legal aspects..." below ▼
Engine Painting:
https://www.4btswaps.com/forum/showthread.php?t=121
https://www.4btswaps.com/forum/showthread.php?t=1463 <=Cummins paint part number
Engine Repairs:
https://www.4btswaps.com/forum/showthread.php?t=9649 <=Why multiple repairs should be avoided if possible
Engine Specifications:
https://www.4btswaps.com/forum/showthread.php?43178 <=Cummins Engine Specs FROM Cummins
Engine Stand:
https://www.4btswaps.com/forum/showthread.php?t=2544 <=Mounting safety
https://www.4btswaps.com/forum/showthread.php?t=3165 <=Choices
Exhaust Brake:
https://www.4btswaps.com/forum/showthread.php?t=973 <=Problems
https://www.4btswaps.com/forum/showthread.php?t=1174 <=Build your own
https://www.4btswaps.com/forum/showthread.php?t=4040
Exhaust Gas Temperature Probe & Gauge, Pyrometer:
https://www.4btswaps.com/forum/showthread.php?t=262
https://www.4btswaps.com/forum/showthread.php?t=3391
https://www.4btswaps.com/forum/showthread.php?t=6330 <=Cruising temps
https://www.4btswaps.com/forum/showthread.php?t=6346
https://www.4btswaps.com/forum/showthread.php?t=8678 <=Rate- rise of temperature
https://www.4btswaps.com/forum/showthread.php?16305 <=Tapping Exhaust Manifold & using particle collector magnets
Exhaust, General Information:
https://www.4btswaps.com/forum/showthread.php?t=1065
Exhaust Header:
https://www.4btswaps.com/forum/showthread.php?t=553
Exhaust Manifold, Bolts and General Information:
https://www.4btswaps.com/forum/showthread.php?t=574
https://www.4btswaps.com/forum/showthread.php?t=535<=Replacing bolts with studs & sources
https://www.4btswaps.com/forum/showthread.php?t=1021<=Manifold bolt part number
https://www.4btswaps.com/forum/showthread.php?t=1848
https://www.4btswaps.com/forum/showthread.php?t=2114 <=Turbo studs
https://www.4btswaps.com/forum/showthread.php?t=2336 <=Freeing rusted & broken bolts
https://www.4btswaps.com/forum/showthread.php?t=3919 <=More broken bolt removal methods
https://www.4btswaps.com/forum/showthread.php?t=4366 <=Flipping over the exhaust manifold
https://www.4btswaps.com/forum/showthread.php?t=6375 <=
FIRE, Leaking manifold sets vehicle alight
Exhaust Manifold Paints:
https://www.4btswaps.com/forum/showthread.php?t=611
Exhaust Pipe Flange to Turbo Using V-Band Clamp:
https://www.4btswaps.com/forum/showthread.php?t=1139
https://www.4btswaps.com/forum/showthread.php?t=1848 <=Adapter
https://www.4btswaps.com/forum/showthread.php?50474 <=
V band clamp data PDF from Eaton
Exhaust Smoke:
https://www.4btswaps.com/forum/showthread.php?t=1550 <=Black
https://www.4btswaps.com/forum/showthread.php?t=3830 <=White on start up
Exhaust System, Misc Pipes & Mufflers:
https://www.4btswaps.com/forum/showthread.php?t=1462
https://www.4btswaps.com/forum/showthread.php?t=1615
https://www.4btswaps.com/forum/showthread.php?t=2194
https://www.4btswaps.com/forum/showthread.php?t=2222
https://www.4btswaps.com/forum/showthread.php?t=2244
https://www.4btswaps.com/forum/showthread.php?t=5055
https://www.4btswaps.com/forum/showthread.php?t=6460
https://www.4btswaps.com/forum/showthread.php?t=6362 <=Some sources
https://www.4btswaps.com/forum/showthread.php?t=7837 <=Short radius down pipe "cobra"
Failure Issues, Mechanical, Engine Problems (Also see KDP Killer Dowell Pin below):
https://www.4btswaps.com/forum/showthread.php?t=9280
Fan, Electric:
See the "Electrical" section
Fan, Hub, Mounting & Bracket:
https://www.4btswaps.com/forum/showthread.php?t=4039 <=6BT info but can apply to 4BT's
Fan, Mechanical:
https://www.4btswaps.com/forum/showthread.php?t=2468
https://www.4btswaps.com/forum/showthread.php?t=4911 <=Autozone part numbers for 89 P30
https://www.4btswaps.com/forum/showthread.php?t=6342
https://www.4btswaps.com/forum/showthread.php?t=8134 <=6BT info but interchanges
https://www.4btswaps.com/forum/showthread.php?108647 <=How To Compact Mechanical fan Using Common Parts
https://www.4btswaps.com/forum/showthread.php?108749 <=4BT Fan Mount Options
Fan Removal & Tools:
https://www.4btswaps.com/forum/showthread.php?t=1942 <=6BT (Dodge) fan set up
Filters, Air:
https://www.4btswaps.com/forum/showthread.php?t=1283
https://www.4btswaps.com/forum/showthread.php?t=1856 <=Air filter flow rates
https://www.4btswaps.com/forum/showthread.php?t=7245 <=Harsh environments
Filter, Fuel:
https://www.4btswaps.com/forum/showthread.php?t=180
https://www.4btswaps.com/forum/showthread.php?t=1698
https://www.4btswaps.com/forum/showthread.php?t=2296
https://www.4btswaps.com/forum/showthread.php?t=6888 <=Cummins dual filter adapter
https://www.4btswaps.com/forum/showthread.php?t=8784 <=Adding filters
https://www.4btswaps.com/forum/showthread.php?t=10997 <=Dual filters with all parts numbers inc filters
https://www.4btswaps.com/forum/showthread.php?t=11271 <=Fuel heater above fuel filter, part#'s, eliminate, replace
Filter, Oil:
https://www.4btswaps.com/forum/showthread.php?t=2287
Filter, Oil, Mounting Housing:
https://4btswaps.com/forum/showthread.php?t=5033
Filter, Oil, Remote:
https://www.4btswaps.com/forum/showthread.php?t=351
https://www.4btswaps.com/forum/showthread.php?t=50&page=6 <=Pic's, part numbers & sources
https://www.4btswaps.com/forum/showthread.php?t=2432 <=Remote p/n & sources
https://www.4btswaps.com/forum/showthread.php?25138 <=Cummins Remote Oil Filter Adapter pt#'s
https://www.4btswaps.com/forum/showthread.php?90417 <=Remote Oil Filter p/n's
Front Fabricated Engine Mounts:
See "Mounts" below ▼
Front OEM Engine Mount for use with SAE Housings:
https://www.4btswaps.com/forum/showthread.php?t=122
Fuel Filters and Mounting:
Fuel, General Info, Additives, Grades, Types:
https://www.4btswaps.com/forum/showthread.php?t=2186<=Waste motor oil
https://www.4btswaps.com/forum/showthread.php?t=2190
https://www.4btswaps.com/forum/showthread.php?t=2191
Fuel Lines, Low Pressure Lift Pump & Return Side, Supply Lines and Tank:
https://www.4btswaps.com/forum/showthread.php?t=1025
https://www.4btswaps.com/forum/showthread.php?t=1375
https://www.4btswaps.com/forum/showthread.php?t=1606 <=Running out of fuel, empty tank hazard
https://www.4btswaps.com/forum/showthread.php?t=2203 <=SAE hose spec numbers
https://www.4btswaps.com/forum/showthread.php?t=2201 <=Dealing with EFI tanks
https://www.4btswaps.com/forum/showthread.php?t=2429 <=Hose types & line sizes
https://www.4btswaps.com/forum/showthread.php?t=3007 <=Larger fuel lines
https://www.4btswaps.com/forum/showthread.php?t=3060 <=Gasoline tank to diesel
https://www.4btswaps.com/forum/showthread.php?16332 <=Fuel filler neck options for diesel pump nozzle
https://www.4btswaps.com/forum/showthread.php?18436 <=
Ran out of fuel and now it won't start. Procedure required for restarting a dry fuel system
https://www.4btswaps.com/forum/showthread.php?18510 <=Setting up a dual fuel supply & dual tanks
https://www.4btswaps.com/forum/showthread.php?27530 <=Injector Return Line Copper Washers Pt# & Repairing broken line
Fuel Pumps, Lift Pumps, Pressure and Gauges:
https://www.4btswaps.com/forum/showthread.php?t=479
https://www.4btswaps.com/forum/showthread.php?t=371
https://www.4btswaps.com/forum/showthread.php?t=1351
https://www.4btswaps.com/forum/showthread.php?t=1393 <=Walbro Electric Fuel Pump Link
https://www.4btswaps.com/forum/showthread.php?t=1442 <=Piston type lift pump install & part number
https://www.4btswaps.com/forum/showthread.php?t=2298 <=Similar to Chevy?
https://www.4btswaps.com/forum/showthread.php?t=2618 <=Interchange between 4BT & 6BT + sources
https://www.4btswaps.com/forum/showthread.php?t=3434 <=Piston style lift pump w/ part #'s (2007)
https://www.4btswaps.com/forum/showthread.php?t=4794 <=Choices & more part numbers (07-2008)
https://www.4btswaps.com/forum/showthread.php?t=7801 <=Electric pumps
https://www.4btswaps.com/forum/showthread.php?t=9461 <=More choices & pressures
https://www.4btswaps.com/forum/showthread.php?t=9438 <=Inlet pressure, vent hole, low mileage failures of new pumps
https://www.4btswaps.com/forum/showthread.php?t=11833 <=Fuel pressure gauges
https://www.4btswaps.com/forum/showthread.php?34769 <=High pressure vs Low Pressure physical differences
Gears, Timing, Gear Case and Mounting Bolts:
https://www.4btswaps.com/forum/showthread.php?t=1888 <=Timing mark positions with #1 cylinder at TDC (VE Pump)
https://www.4btswaps.com/forum/showthread.php?t=10257 <=Timing gears, pump, rotating with pump removed
Generator Set Engines:
Glow Plugs:
https://www.4btswaps.com/forum/showthread.php?t=3671 <=Pertains to all Cummins B Series engines
https://www.4btswaps.com/forum/showthread.php?t=3772
Grid Heater, Mounting & Related Intake Parts:
https://www.4btswaps.com/forum/showthread.php?t=2469
https://www.4btswaps.com/forum/showthread.php?t=2476 <=Wiring diagram (push button)
https://www.4btswaps.com/forum/showthread.php?t=8505 Retrofit, adapting
https://www.4btswaps.com/forum/showthread.php?38362 <=Grid heater hook ups
Head:
See Cylinder Head /\
Heater Hose Connections to Engine:
https://www.4btswaps.com/forum/showthread.php?t=425
https://www.4btswaps.com/forum/showthread.php?t=1192
History of the "B" Series Cummins Engine:
https://4btswaps.com/forum/showthread.php?t=1206
https://www.4btswaps.com/forum/showthread.php?t=9691
https://www.4btswaps.com/forum/showthread.php?19645 <=Happy birthday to the B-series Engine July 1st!!!!
Hose, Radiator:
"See "Coolant Section" above
