21 - 40 of 55 Posts
FAQ: Commonly Asked Questions, 4BT Files, Photos, Links, Etc....
Most of this applies to 6B's, but there are many things here that work just the same for the 4B. I will keep this current with more to come.
3900955 Metal expansion plug. (Little plug that fills in the little hole in the block, where the old dipstick went, front sump v.s. rear sump.) All years.
3928740 Oil dipstick. 12 & 24 valve.
3905801 Oil dipstick tube. (Plastic.) 12 & 24 valve.
3280885 Oil gage metal. (The metal piece that is in-between the plastic dipstick tube and the block.) 12 & 24 valve.
4089093 Oil pan. (Aluiminum, the least expensive replacement pan.) 1994-1998. 12 valve, fits 1989-2002 engines.
3938455 Oil pickup/suction tube. 12 & 24 valve same as oil pan.
3914383 Pick-up tube gasket. All years.
3926910 Oil pan plug. 12 & 24 valve.
3902425 Oil pan copper washer. 12 & 24 valve.
3902605 Valve cover w/plug. (Changes from the Dodge style oil filler area.) All 12 valve engines. 1989-1998.
3903463 Access cover plug. (Covers the hole where the Dodge style oil filler neck was.) All 12 valve engines. 1988-1998.
3939258 Lift pump gasket. 12 &24 valve.
3969988 Air intake gaskets. For 2003-2006 24 common rail, will work on 12 valve.
3920779 Short head bolts. (X6) All 12 valve engines.
3920780 Long head bolts. (X14) All 12 valve engines.
4089648 Complete upper gasket kit. 1994-1998. 12 valve.
3802376 Complete lower gasket kit. 1994-1998. 12 valve.
3911660 Fan hub kit. (EXPENSIVE little kit.) 1994-1998. 12 valve.
3911668 Fan drive to hub bolts. (X6) 1994-1998. 12 valve.
3902114 Fan hub to block bolts. (X4) 1994-1998. 12 valve.
3931744 Cummins 12 valve exhaust manifold. Turbo outlet pointing straight down between #5 & #6 cylinder (for much better air box clearence-tighter to the engine)
3973422 Heres another manifold that also has the port outlet straight down, but this one has the outlet in the center of the manifold, between #3 & #4 cylinder.
'69 FJ55 Land Cruiser
Discussion Starter #22
I went ahead and moved the torque values into this thread to clean out some of the excessive stickies...
Adapter plate bolts
I was looking in FAQ and could not find. Do I have to go to Cummins for the adapter plate bolts or are they standard grade 8's? I know the torque spec of 101 ft lbs. Thank you.
From the bolts.doc in this thread from the above posting:
Housing to block/ Flywheel-Housing/ 3920447/ 8 each/ M12 x 1.75 x 40
There are a lot of 6bt's here with the Bosch A-pump. Its basicallly used as an Industrial type engine though a few trucks use it also. All in all, a very noisey pump, as all inlines are, with the max factory rating at [email protected] in the 6bt, coz the ones that make the higher ratings have the Ve till about 210hp, after which the P-inline takes over.........
They are the same people as www.shipanengine.com that showed up in this thread:
http://www.4btswaps.com/forum/showthread.php?t=4874
They came in and faked a positive review of the company and got banned from the site for their trouble. I also found with a quick bit o' Google where they had done the same thing on other sites, and even used the same user name!
Personally, I won't do business with folks that do that. And, from the last post in the thread BobS linked, they turned out to be about what was expected: Cheap and flakey.
The Densno # here crossed over to a rebuilt AC Delco
ACD # 336-1623
GM # 19135477
Starter part number cross reference information for folks using Dodge Cummins engines, adapter plates, flywheel housings and etc:
1994-2002
Cummins 3921682
Denso 228000-2290
Lester 17548
Lester is generally the standard interchange reference number between various manufacturers. Cummins part numbers are generally the most expensive and are subject to frequent change. Denso is the OEM in most cases.
do any of u guys know what the torqe specs are for the cummins 6bt engines??
thanks!!
thanks!!
Did you by any chance misread post #4 in this thread? :idea:
Thanks for all your work, now if I only had about 5 yrs loose to study it all . Send info on how I can bookmark this and other tech info. GREAT WORK!!!!
Manuals
OK! Just click on the link labeled with the manual you want, and click the download button. Thanks to BobS for suggesting 4shared.com. It was easy to use, and all yall get this stuff for free!!
4BT Manuals
Cummins 4BT Service Manual (85.7 MB)
Cummins 4BT Owners Manual (17 MB)
Cummins 4BT Parts Catalog (23.4 MB)
Cylinder Head Capscrew Torque Manual (722 KB)
4BT and 6BT Parts Catalog (520 KB)
4BT and 6BT Parts Catalog Prices (611 KB)
4BT Power Curves (133 KB)
4BTA Power Curves (137 KB)
4BT Dimensions 1 (700 KB)
4BT Dimensions 2 (919 KB)
4BT CPL767 Datasheet (76 KB)
4BT CPL767 Power Curves (79 KB)
4BT Starter Cross Reference (11 KB)
4BT to Ford SB Automatic Transmission Parts List (10 KB)
6BT Manuals
6BT Parts Manual (1.4 MB)
6BT Power Curves (134 KB)
VE Pump Manuals
Bosh VE Pumps Manual (1.6 MB)
ZF Transmission Manuals
ZF S5-42 Datasheet (69 KB)
ZF S5-42 Reman Specs (29 KB)
ZF S5-42 Transmission Years (29 KB)
ZF S5-42 Diagnosis and Testing Manual (758 KB)
ZF S5-47 Datasheet (85 KB)
ZF S5-47 Service Tips (844 KB)
ZF S5-47 Description and Operation Manual (800 KB)
ZF S6-650 Datasheet (162 KB)
ZF Application Progression Chart (13 KB)
ZF Cross Reference Chart (116 KB)
ZF Clutch Manual (66 KB)
E4OD to ZF 5 Speed Conversion Guide (24KB)
ZF Wiring Diagram 1 (29 KB)
ZF Wiring Diagram 2 (29 KB)
ZF Wiring Diagram 3 (27 KB)
Other Transmission Manuals
NV3550 Transmission Manual (1.4 MB)
Dodge Transmissions A500/42RH/A581/46RH/A681/47RH Manual (23.4 MB)
47RH Valve Body Installation Guide (1.4 MB)
Tubocharger Manuals
H1C Service Manual (3.9 MB)
WH1C Service Manual (4.8 MB)
HY30W Service Manual (4.8 MB)
HY35W Service Manual (5.5 MB)
HX30/32/35/38/40 Service Manual (5.7 MB)
HX50/55 Service Manual (4.3 MB)
HX50W/55W Service Manual (5.2 MB)
HE300W Series Service Manual (4.9 MB)
HE341VE Service Manual (1.1 MB)
HE351CW Service Manual (2.2 MB)
Other Various Manuals
NV4500 Exploded Diagram (156 KB)
NP205 Manual (337 KB)
PTO Application Information (37.5 MB)
Pac Brake Information (1.1 MB)
ARTSA Fuel Efficiency Lecture (1.8 MB)
I will post any more good information I find here. Happy Reading!!
Would any one be interested in this Cummins install guide?
It's 25 pages, I've scanned the pages into .jpg files, full size is 71mb.
At 1/3 size, still readable but some of the images are a little fuzzy, its 7.7mb
All of the files an on 4share.
Heres the link_to_Cummins_manual_on_4share
Each .jpg is about 500kb.
Hangs Out With Dogs
Anyone have the part number for 4bt Ford Motor Mount adaptors - the part that bolts to the block?
21 - 40 of 55 Posts
