The first Fleetwood Flair thread started in 2011. Documented install of Cummins 6bt and Dodge 46RH trans in a 1990 Fleetwood Flair RV. Really good service til winter before last when trans failed. The steel lines to atf cooler sprang a leak and lost atf and trans.
So this thread documents trans replacement. Bought a Allison 545 for three hundred came with adapter and flywheel. Not the most popular swap but we shall see. Is the last fully mechanical Allison trans and most durable some say. 4 speed even ratio spacing no overdrive gear.
Started today. Drive shaft out trans on trans jack bolts loose. 46RH out tomorrow. Will post more as progress...
