1 - 8 of 8 Posts
Yes, I've searched around and cant find the answer. If I dont get an answer today I'm torching it off.
I have 4bt that came out of Franklin feller buncher, I cant for the life of me get this dang flywheel off. It has bolt heads around the middle, and I loosened them but all they do is spin and wont come out. There was allen head bolts all around the outside edge of flywheel kinda like a cover I guess? I took them out and still nothing.
I've beat on it with a hammer, more than enough to jar something loose. My next option is Acetylene torch. Help please.
What you're seeing there may not be the actual flywheel that is bolted to the crankshaft. No surface area there where a clutch disc would have been . Probably for some type of automatic transmission. It's either SAE3 or SAE2. Is there a serial number on the engine. If so, I could look on Quick Serve and see if there's a parts diagram. Have you removed the starter or one of the plugs in the the flywheel housing to look in from the other side. Don't want to go using a torch except as a lat resort.
That is a drive adaptor on the flywheel. It is counterbored into the flywheel and maybe just rust/tight fit locking it into the flywheel. The centre bolts will just be holding the plate to the splines and not the crankshaft
May need to get a big slide hammer to go into the splines and pull it from there. Could try a pipe or decent bar in the splines and try rocking it to break it loose. While you have a bar in there with load on it, use a hammer to tap around the edge of the adaptor plate.
Cheers Steve
Big thank you. I couldn't find a diagram anywhere to show me how this works. Heres a picture in case someone else struggles
Discussion Starter #7
That metal bar in picture I stuck in the flange, pulled on it (hard) and struck it with big hammer. After several good licks it come loose.
Then I was able to unbolt flywheel and adapter. In the process of building an engine stand and adapter and flywheel was last to be removed
1 - 8 of 8 Posts
