1 - 7 of 7 Posts
...maybe tomorrow (and I've been saying that for a month now :confused: ). But tonight is Fried Day...:beer:
Actually, the thing was ready to for first fire a week ago but the starter wouldn't work and the water pump leaked, so while the truck was down anyway I used the opportunity to "bulletproof" the installation, make some changes, and generally finish, i.e., tear it back apart and do some of those "do it later" tweaks...you know, the labor-intensive ones that never get done.
Anyway, hi.
Eddie
Eddie,
At least your making more progress on this than that ol bucket of rust you call a Scout!:D Cool!
Good to "hear" from you.
Got to get back out to the barn before my better half gets home and finds me on the computer.
Steve
You haven't heard the last of the Scout project, not by a long shot. It will come back to haunt you, ummm, some day, and it sorta may not look exactly like a Scout.
The two projects are simply not comparable; the truck was a clean, unrusted, tight sorta late-model that I'd owned since new that sorta had a blown gasoline engine. (Heavy sarcasm) ALL it required was a simple engine swap.:rasta: (Ummm, is there anything on the truck that I haven't tweaked, modified, adjusted, replaced, spilled beer on, or cussed out?)
The Scout, OTOH...:nuke:
Eddie
That Scout, when its done will be the envy of all Scout lovers, a toast :beer:
I have my own, well my wife's rust project, the Willys. Only been on it for 3 years, a least. I know what you mean.
Steve
Discussion Starter · #6 ·
No Pics Just Yet, But...
...I did finally get a camera, and took a bunch of pics of a little starter problem I was havin'.
And I did finally spin the motor, which ends that recurring little thot "What if the thing is rusted solid inside and won't turn" It didn't start up, though; I think its a fuel problem.
I noticed that the fuel pressure gauge was reading "0", which provides me just the impetus I need to return to the OE Cummins mechanical piston pump and lines and do away with the Ford in-tank electric crossbred morphodite setup I thought I'd try to begin with. Install the new plastic tanks I just happen to have, too.
Gee...with those fuel tanks installed, I can run B100...just in time for the
Annual Summer Petrol Price Gouge. :nuke:
Eddie
Discussion Starter · #7 ·
It's There!
Thing drives nice.
I just had a 3.08 R&P put in (bought for $15.00 w/carrier off eBay).
The trips are getting longer daily, followed by the "shakedown" :rolleyes: (literally) repairs and general Make-It-Pretty reworks, but...it runs great and drives just great.
Last bit of outside shop work will be a front end alignment, necessary because the 3/4-ton coil springs added a couple inches of front end lift and therefore some excessive positive camber; and that needs to wait until I can dumpsterize this junk engine in the bed...which may be the cause of the front end llift...
Eddie
1 - 7 of 7 Posts
