why is my fuel consumption around 17-19mpg it seems kind of low on the mpgs???
anyone have any input?
Did you also use the GPS to verify the distance traveled?3:31 gears
31 inch bfgs
weight about 3500lbs
around town and highway it dosen't seem to change
trans 700r4
rpm at 65 was about 1800
no mods
3inch exhaust
4bta with an alternator and ps-pump
I used a gps to verify the speed...
Both times were until I absolutely could not get any more in. Fill, let foam die, fill, more filling, even more with the foam until I had fuel right up to the cap both times....Did you fill it up the filler neck before and after the trip - or did you just fill till the pump shut off?
