1 - 7 of 7 Posts
Hello all and happy Thanksgiving! Can someone please tell me if the fuel line going into the injection pump is supposed to have an o-ring, and if yes what size please? Mine is leaking some and I am hoping it is just missing the o-ring…..
It is a VE pump 0460424027 on a 4BT
They have flat/copper washers for a seal. Have you had the Banjo bolt out and dropped the washer?
Could try gently tightening the Banjo bolt.
Vendor
After seeing pic below I gave wrong info. Theres no sealing washer there. Its a compression fitting
There are 2 fuel lines connected to the injection pump. There is a feed line from the fuel filter and that one shows no sealing washers of any kind. See diagram below. The second line is a fuel return and it has a banjo type fitting and would have 2 flat sealing washers. I believe the part number for those is 3963983. If there is any type of washer on the pump end of the feed line Cummins doesn't show it.
Font Auto part Circle Diagram Science
Sorry, I have a banjo on mine but originally it had an adapter in there and the original line had a compression fitting on it.
The adaptor has a sealing washer the same as the banjo bolt.
Product Automotive tire Vehicle Motor vehicle Wood
1 - 7 of 7 Posts
