21 - 33 of 33 Posts
Trip mileage: From Mesa AZ (elevation 1200 ft) to Chiricahua Natl Mon (elevation 5124 ft). and back, 535 miles (861km)
Four days , three nights.
The Scout towing the Casita 17'.
Speed: set for 65 mph, (104 km/h), 1900 RPM.
Stuck to back roads where we could, most were posted for 65 mph, some less, some freeway.
Gross Combined Weight, about 8000 lbs, (3628 kg)
Mileage up to Chiricahua Natl Mon, , 17.42 mpg
Return milage 19.91 mpg
Trip average 18.66 mpg
Fuel cost per mile @3.99 gal $0.23
Not bad for a big heavy beast!
Last Saturday trip up to Tucson (el 2400 ft) and back home (el 1200ft), 372 miles, 16 gallons used, 23 mpg.
Going there was via I10E, 70-75mph. 6 hours of back roads (mostly 2nd gear) to the top of mount Lemon (el 8000 ft).
Going home 4 hrs, took state roads via sr79 through Florence. about 65 mph.
Since I've put my 4BT in last December / January, I've put ~10,000 miles on her. 99% of tanks I've burned have ranged between 20 and 22 mpg, with the very first tank after the conversion clocking in at 19. The majority of my driving is back and forth in the Piedmont region of NC (max ~50ft to 800ft elevation). I did take her for a trip to upstate NY earlier this summer, as well as a trip to PA.
1987 Toyota Land Cruiser
CPL 858, stock injectors, full power screw 1.5 turns in, HX30w12
Dodge NV4500HD
Dana 300
14 bolt rear axle
3.73 gears
37x12.50r16.5 Military OZ tires
Trip to Salida Colorado via Wolf Creek Pass (10500') from Mesa AZ and return.
1390 miles, 75.5 gallons used= 18.16 mpg. $205.95 cost of fuel. Cost per mile $0.148 per mile
Gross combined weight estimated at 8000 lbs.
Mesa to Durango 17.1 mpg
Durango to Salida, Rawley mine, trip to Walmart and back to Durango 18.9 mpg
Durango to Mesa via Salt River Canyon 18.8 mpg
Had to use Google maps and other resources for milage calculation, speedo cable broke day before trip.
Interesting. I can't get more than ~16mpg towing this trailer with stuff. Total weight is somewhere around 10k (loaded, measured). I can feel a significant difference at speed between that canvas top being on and off:
Interesting. I can't get more than ~16mpg towing this trailer with stuff. VVWR is somewhere around 10k (loaded, measured). I can feel a significant difference at speed between that canvas top being on and off:
I would say aerodynamics of the trailers has something to do with it and then the weight. I kept my speed at 60 to 65 mph. (1700 to 2000 rpm)
So far the best I've gotten was 11.54 mpg out of my landcruiser. But I do not have OD , 4.88 gears with 44" tires and it weighs about 6300 pounds. So with that being said I'm getting almost 7mpg better than the gas 350 I pulled out. My engine only has about 700 miles on the rebuild. I think when I go to smaller injector and the engine breaks in I hope to get around 15mpg. Here is what it looks like today
Since changing to the ZF's .76 OD from the M5od'd .8 OD on my last fueling I got a solid 20mpg with 500 miles of mixed highway,town and interstate driving.That is with 3.55's and 33" tires interstate speed limits are 75mph.
With 275/60r15 tires and 2.73 gears I was able to go 237 miles with around 100 of those miles was towing a trailer that weighed 2000-6000 pounds. Truck weighs around 4000-4500 pounds. I got 20.8 MPG, which I'm super happy about.
-vr4oaks
Not that anyone cares anymore, but I will throw in an update. I have been getting pretty consistent mileage and still getting everything dialed in. Seeing 14 as the lowest and 18 as the highest for mpg. Mixed driving or mix of offroad trails and highway I'm getting 16. I think I could get 20mpg if the conditions we more ideal. Every time I get 18 on the highway I have been pulling multiple 10,000-11,000ft elevation passes and/or having a 30mph head wind and not able to lock up the TC for alot of the time.
This is all with 4.88 gears, a 700R4, and 42" tires hand calculated to account for tire diameter and same fuel station pump.
After the rebuild and adding compounds and 5 x .012" injectors I'm averaging 17-18 mpg that has been pretty constant over the last 10,000 miles...........................DRIVING IT LIKE I STOLE IT as always ;)
21 - 33 of 33 Posts
