1 - 7 of 7 Posts
· Registered
I was out priming my fuel pump (W/ the hand primer on lift pump) thinking fuel would be coming out the injector tubes but fuel keeps coming out the return lines right at the injectors am I doing something wrong ?
· Registered
i"ve cranked the motor but theres no pressure out the inj lines . I've even cracked the lines coming out the inj pump but still no fuel anybody have any suggestions ? Does the return line bolt up to the back of the inj pump ?
· Registered
OK I was in church not listening to the message but thinking instead of my 4b , I forgot all about that solenoid . I still don't have a prime from my oil pump but I think I'll try a few things I've done before to get a pump to prime . Thanx for the reply !
· Registered
Discussion Starter · #7 ·
prime
Yes thank you ! I just sold a new turbo (H1C) to a customer if mine for a Case 580 SK backhoe. I was looking in the box for the gaskets & came across the prelube instructions so I took a copy.
1 - 7 of 7 Posts
