mainly in tractors (massey-ferguson and some old fords, among others) and airport ground-support vehicleswhat is that engine usually found in?
Could you keep the stock trans I heard some one say the gas and diesel transmission are not interchangeabledodge gas to diesel swap This imo is one of the easier swaps. Dodge has done most of the work for you. I drive a 1989 dodge Ram Charger with a cummis 4BTA and 518 transmission. I have driven it for 3 and a half years put 120,000 miles on it. There were very few modifications. The truck actually weigh 100 pounds less than stock. Good Luck
The Dodge diesel transmissions have a different bolt pattern on the bellhousing interface.Could you keep the stock trans I heard some one say the gas and diesel transmission are not interchangeable
Ok if that's the only difference then perhaps the correct plate can solve it or a bell housing swap. I didn't know it was 10 years old but I still got a response so I guess age doesn't matter on this oneThe Dodge diesel transmissions have a different bolt pattern on the bellhousing interface.
p.s. Did you notice that this thread is over 10 years old?
Russ
