1 - 7 of 7 Posts
Is the overdrive in this trans actualy 31%? The tranny is out of '92 dodge diesel 4x4. I am considering using it in a conversion with 3.54 ratios in the rearends, but am concerned my gears will be to steep for the 4bt. Any info would sure help.
Thanks,
Dallas76
How tall of a tire are you planning on using?
What your usage profile going to be - highway usage? daily driver? weekend warrior?
The 518 has a 2.45 first gear so you don't have to worry as much about spinning through first as quick as say a 700R4 (3.06 1st) or any of the manual transmissions (all above 5.00). Heck, almost all of the stick's 2nd gears are higher than the auto's 1st gears.
My plan is to buy a dodge 4x4 diesel pickup (1990-1994), sell the 5.9 out of it minus the bellhousing and a few other components. Then use the tranny, transfercase, and front and rear ends under a 1967 ford f250. The rear ends are 3.54 with 255/85 16. With all that, I figure that at 1800 rpm I'll be going 71 mph in 4th gear but in 3rd at the same rpm I'll be at 49 mph. Every thing that I read on this site says that for optimal fuel economy I want to run at 1600-1800 rpm. Most of my driving will be maybe at an average of 60, that puts my rpms at 1517. Do you guys think that is to slow rpms?
dallas76
With that 7,000 lbs truck I wouldn't go higher than 4.1 on gear ratio, which should be the stockers. You need the lower gears to get it up and going. Still allows a good cruising speed stock, or you can add a 3,200 governor spring. You'll get good mileage with those gears. Nice thing is you also save some considerable money on a gear swap.
1 - 7 of 7 Posts
