1 - 9 of 9 Posts
Do you guys think that gears of 307 with 35 inch tire is to lower and the 4bt will struggle?
Depends on the vehicle...jeep, no....1 ton 4x4, yes.
it's going to be in a 1970 Bronco
Most tires are not a true 35'' so it will also depend on your trans auto or manual ,will be great on fuel milage.
Scott
i am planning to put the zf 5.
I would think it should be okay. If it is a little lazy, that can be fixed easy enough with some tuning.
The engine probably wont struggle with it, but that might be a little tall. You'll only be turning 1400-some RPM at 65. Well below the 1600-1800 sweet spot. With a new governor spring youd be geared to do over 140.... :massey: [Yes, I know, no way in hell a brick like an EB will do 140].
Gear Calculator: http://www.izook.com/gearcalc.htm
Discussion Starter · #8 ·
Yeah but how cool would it be to see a EB do 140 of course there is know where to do it but that would be awesome.
I don't think it's to low.
I put 4.88 gears with a NV4500 trans in my jeep. I can still go 72 MPH (on good roads). If your going to be of roading I'n go with 3.77 or lowwer. Just me and my prefferences. Good luck.
1 - 9 of 9 Posts
