1 - 4 of 4 Posts
Hello,
I finally decided to use the Dodge D60/D70 from my W350 in my '63 Jeep J300. The tag in the rear diff. says the gearing is 3.07, which makes the front axle a D61.
My plans are to use these axles along with a NV4500 and a 4BT with the rotary pump. This truck will be use to haul medium sized loads and (very) occasionally tow a 4400 lb car (a 1966 Olds Toronado). With 31" tires, this combo puts the RPM's at 1600 at 65MPH and 1800 at 75MPH. This would make for a nice highway cruiser, but considering the modest output of the 4BT, how bad is it going to be as an occasional tow vehicle?
Thanks,
Mikel
actually I think that is honestly perfect gearing IMO. I would love to have that gear ratio.. Again slight bump in fuel and turbo and it feels like a V8 on the highway I would say with minimal loss of economy... Won't tow like a real tow rig but you will be fine :)
Can 160HP/400ft-lbs be achieved easily with the rotary pump? Will vibrations increase significantly?
Thanks,
Mikel
If its only going to be occasional towing you can always run in 4th at say 60-65 and turn about 2100-2250. I'm planning on running 3.08 with a 90 F150 with a ZF5 and 33" tires. It should be right at 1700 @ 70. If I tow I can run in 4th at 2080 @ 65.
1 - 4 of 4 Posts
