some good Spring info on there..
Chevy Springs.....
Please note this is a work in progress, from the internet......So far I have........measurements are spring eye to center bolt, center bolt to spring eye...
Chevy / GMC Front Leaf Springs
1956-59 GM 1/2, 3/4 ton Pick up (measures 22 x 22, 6 leaf, 2" wide)
1968-72 GM 4x4 Pick up, Blazer, Suburban Heavy Duty (measures 22 x 22, 3 leaf)
1973-87 GM 4x4 Pick up, Blazer, Suburban (measures 23-1/2 x 23-1/2, 2 leaf)
1973-87 GM 4x4 Pick up, Blazer, Suburban Heavy Duty (measures 23-1/2 x 23-1/2, 3 leaf)
1988-91 Blazer, Suburban Heavy Duty 2250 lbs (measures 23-1/2 x 23-1/2, 3 leaf)
1947-54 GM Pick up (measures 25-1/2 x 29, 8 leaf 1-3/4" wide)
1955-59 GM 1/2 ton pick up (measures 26 x 26, 7 leaf, 2" wide)
1955-59 GM 1/2, 3/4 ton pick up (measures 26 x 26, 9 leaf, 2" wide)
1955-66 Chevy, GMC (measures 26 x 26, 8 leaf, 2-1/2" wide)
1969-72 GM pick up 2 wheel drive (measures 24 x 28, 6 leaf, 2-1/4" wide)
1973-87 GM 1/2 ton pick up 1550 lbs (measures 26 x 26, 4 leaf, 2-1/2" wide)
1973-87 GM 4x4 pick up, blazer, jimmy, suburban 2000 lbs (measures 26 x 26, 5 leaf, 2-1/2" wide)
1973-87 GM 4x4 pick up, blazer, jimmy, suburban 2450 lbs (measures 26 x 26, 6 leaf, 2-1/2" wide)
1973-87 GM 4x4 pick up, blazer, jimmy, suburban HD 3100 lbs (measures 26 x 26, 7 leaf, 2-1/2" wide)
1973-87 GM 4x4 pick up, blazer, jimmy, suburban XHD 3750 lbs (measures 26 x 26, 8 leaf, 2-1/2" wide)
1973-87 GM pick up, suburban 1800 lbs (measures 26 x 30, 5 leaf, 2-1/2" wide)
1973-87 GM 2wd pick up, suburban 2200 lbs (measures 26 x 30, 8 leaf, 2-1/2" wide)
1973-87 GM 2wd pick up, suburban 2600 lbs (measures 26 x 30, 9 leaf, 2-1/2" wide)
1980-91 GM 1 ton with overload leaf 3500 lbs (measures 26 x 30, 9 leaf + overload leaf, 2-1/2" wide)
1980-91 GM 1 ton with 9/16 bolts 3950 lbs (measures 26 x 30, 10 leaf, 2-1/2" wide)
1980-91 GM 1 ton with 5/8 bolts 3950 lbs (measures 26 x 30, 10 leaf, 2-1/2" wide)
1988-present GM 1/2 ton pick up 1425 lbs (measures 32 x 32, 4 leaf, 2-1/2" wide)
1988-present GM 1/2, 3/4 ton pick up 2025 lbs (measures 32 x 32, 5 leaf, 2-1/2" wide)
1988-present GM 3/4, 1 ton pick up 2335 lbs (measures 32 x 32, 6 leaf, 2-1/2" wide)
1988-present GM 3/4, 1 ton pick up with 3 leaf overload 2810 lbs (measures 32 x 32, 6 leaf + 3 leaf overload, 2-1/2" wide)
1995-2000 Blazer, jimmy, bravada 1400 lbs (measures 24-1/2 x 27-1/2, 4 leaf, 2-1/2" wide)
1995-2000 Tahoe, Yukon, Escalade (measures 27 x 27, 5 leaf, 2-1/2" wide)
1995-2000 GM S-10, S-15 pick up (measures 26 x 28, 3 leaf, 2-1/2" wide)
1995-2000 GM S-10, S-15 pick up heavy duty (measures 26 x 28, 4 leaf, 2-1/2" wide)
1995-2000 GM S-10, S-15, Sonoma ZR2 4x4 (measures 25-13/32 x 28-19/32, 4 leaf, 2-1/2" wide)
