My experience is with Cummins/Dodge NV-4500's. My next truck will require a 2 wheel drive NV-4500 driving a Divorced T Case.
I have located a GM-NV-4500, 2 wheel drive with the short Tailhousing and fixed Yoke.
The GM NV-4500 comes with the following;
NV-4500
Bell Housing is for a Small Block Engine
Manual Transmission Flywheel
Starter
Clutch and Hydraulic Throwout
I already have a Cummins/GM Flywheel Housing.
Am I correct in thinking that the Small Block Bell Housing will bolt to the Cummins/GM flywheel housing and all be a bolt up Plug and Play ? The entire clutch will be replaced prior to install. Am I missing anything.
Thanks Paul
NV-4500
Starter
Thanks Paul
