the brakes work ok but if im at red light or idleing for a while i gotta push hard real hard. i dont know the inner workings of a break booster its a 1993 truck no air bags or abs,i think there is computer hanging on the master cylinder what could it be for???? is the mercedes vacume pump not strong enough? the brakes worked great with the 4.3 gasser even with 33'' baja claws mud tires. the 20'' wheel and tire are 31 inches tall and llighter than the old 33s????
as for the temp guage theres five volts at the connector as there should be it has ground i would realy like use the factory guages for a clean factory looking truck, would the ecm be not letting it work the oil pressure sending unit works and cut and spliced(with solder not cheepo wire crimps) the pigtail so it would reach. the temp sensor is the stock location all i had to do was retap the hole for the gm cts ????
for the wipers i havent messed with them yet just checked the fuse(not blown) wiper tank is empty would that make them not work????
ill post another video soon
