Hi guys!
Well, I'm doing it: just swapping out the compressor & impeller on my Holset. I've heard mention on 6BT forums about a 'silencer ring' that can be removed. I don't see any such animal!?? Does the stock CPL858 4BT H1C use this silencer ring? Thanks!
Impeller shaft has a wee bit of play side to side, none in thrust, but that will have to wait until next time. Also some carbon on inside back of impeller/compresor housing and back of impeller. Doubt it should be there....?
Oh, another thing: The HTT kit came with a flange gasket, plus a small O-ring, about 1/2" I.D.. Is this something I need to change somewhere, like to stop this exhaust carbon leak?
