1 - 5 of 5 Posts
What is making my 2005 5.9 hard to start when the night time temps are below 50. The engine seems to turn over slower at these temps. I have replaced the batteries. 50 degrees is not that cold.
Are your toaster ovens working at that temp? How about starter, cables, should spin OK at that temp.
Ed in CO.
Heater "toaster oven" works. I havent replaced any cables. I would imagine that the starter, if bad, would be slow at any temp. I plug in the block heater when below 50 and everything works as it should.
Might inspect you starter cables for signs of corrosion. Same for the ground wires. A bad ground can have a big effect on the starter circuit. A weak starter can also be suspect. Oil is a bit thinner at higher temps so it doesn't pull as hard. A few years back I replaced the positive cable on my old Ford 7.3 and the starter as well. Was expensive but it was like night and day difference.
1 - 5 of 5 Posts
