1 - 2 of 2 Posts
Gentlemen-
I've been looking heavily into running a HE351VE w/ steed's controller. There will also be other performance mods to accommodate the additional air flow. I was planning to use a 12V manifold with the front and rear cylinder inlets removed and plugged. Now for the questions:
Has anyone run into problems with the cool side of the turbo running into the oil filter?
What are people using for coolant lines? I believe the turbo uses banjo bolts? it is possible just to use a barb fitting instead of a banjo and just run the lines by t-ing off the radiator inlet and outlet hoses?
What are people using for oil lines?
Thanks in advance.
Vendor
I used a center dump manifold and a adapter, to make mine fit youll need spacers between the manifold and head. Youll also need to relocate your oil filter.
Depending which manifold you use and if its upside down or not will determine what youll need.
As far as water lines I used an10 hoses. I took the heater port behind the thermostat and the water inlet on the bottom of the lower water neck for a return. .
1 - 2 of 2 Posts
