The setup I proposed already uses wastegates on both turbines. 65psi is not enough to deliver the required air-flow that 90psi does.Look, I was simply showing an example of how wastegating can reduce drive pressure and increase efficiency of a turbo setup. My original comment was a simple alternate solution to an issue brought up by the OP concerning the secondary turbo he was considering using in his twin setup. For some reason you took offense to my ALTERNATE SOLUTION.
I wasn't arguing that you were wrong. I wasn't talking about completely bypassing the secondary turbo. Just using a wastegate to divert some of the exhaust energy around the turbine to prevent an excessive amount of restriction. Routing the "wasted" exhaust energy into the intermediate pipe helps to recover that energy rather than dumping it to the atmosphere. The primary still operates at around 2.5-2.8:1 pressure ratio, and the secondary around 2:1, generally resulting in measured total boost of about 65 PSI. I use the wastegate to help fine tune the drive pressure and get the boost/drive pressure ratio as close to 1:1 as possible without significant performance loss.
In a perfect world spending thousands of dollars on different turbos to presicely match the application would be ideal, I agree. I don't usually have the luxury of custom designing a turbo setup to perfectly match the engine. By the time I see them the turbos are already there, but for multiple reasons the system is not performing as it should or is expected to. So I diagnose the problems and come up with solutions to not have to completely re-invent the wheel to come up with compromise that is acceptable to the customer. On some occasions I can make recommendations and help my customers decide on what compromises they are willing to make with a kit design. There is too many variables beyond the turbos themselves to list out examples. What I do know is I have a very good track record and reputation of improving the overall drivability and usability of theses setups.
Clearly you have what I assume is an engineering back ground based on your methodology. Good for you. I am not going to have a continuing pissing match with you over this.
Possible 500hp 4BTT Power Recipie.
So Fnnissan asked me which turbos would be needed to get 500hp from a 4BT. He piqued my interest so I ran some calcs. First a disclaimer. I am working on severely limited data and don't even have a 4BT to test this on. But I'm confident my numbers will give results within 10% or so. I have...
