This FP3804896 seems to be quite cheap....
The parts l got for my tractor were FP Diesel , Federal -Mogul motor parts apparently made in India ,. My research said high quality. From <agkits.com>Felpro vs Cummins 12 valve gasket comparison:
You will not go wrong with MAHLE, as they manufacture parts for the Top Tier diesel engine manufacturer,s . The Cummins 5.9 was designed, and some were manufactured in Europe !When I replaced the head gasket on my 12V I got a gen-u-ine Cummins gasket from Cummins Rocky Mountain. Don't recall how much I paid, but I get prices at a shop rate so I didn't have to pay full boat. Anyway, I was very disappointed when I saw the label in the package said "Made In China". Had I known that and not needed it immediately I would have gotten a Fel-Pro or Mahle instead. They might still be made in China (hopefully not - My motto is Made in USA first, anywhere but China second), but at least I wouldn't be lining Cummins' pockets with extra money. I will spare everyone my rant on how much Cummins parts are being made in China these days, but let's just say I wouldn't buy anything with a new Cummins engine in it anymore.
I will acknowledge that the gasket was excellent quality and is holding up fine even with the less than flawless deck surface it has to seal to.
Well, Im too late, but I was going to warn you against having the head surfaced unless its needed. There is a spec for this. All that is needed is a machinists straight edge and a set of feller gauges. Most of the time, heads (and decks) are well within spec. So, surfacing isnt needed. This saves money, time, material, and valve to piston issues on some engines.Awesome thank you ! My motor is a Cummins recon. I’m not sure either if it’s been machined before or not , how do I know which gasket to go with? I’m going to take the head to get planed this week , not sure if I should go up a size on the gasket or not ? Also thoroughbred diesel sells a 4bt headgasket kit built by mahle , not sure if those are good to use or not ?
