Trying to put the finishing touches on a 4BT for 6.5 swap in a 97 H1 Hummer. Does anyone know of a flywheel cover that will work with a 4BT/4L80E combination, or do I have to fab one myself. Also, I have a crank pulley off of a 6BT (out of a dodge) with 2 notches for the crank position sensor, and a dodge cps. I am trying to make the stock tachometer work, but tried to wire up the existing harness that went to the 6.5 cps to the dodge cps (both had 3 wires), with no luck making it work. Does anyone know how I can make it work, or do I have to install a different tachometer? Thanks for your help Ron
