Ok bought a motor , cleaned it up had to make some changes ....I changed the oil pan and pick up to an industrial pan and pick up .....then i needed to chane the oil filter adapter to a different style ...went from one that had the filter straight out ....to one with it facing straight down ...put everything together and went to crank motor over for first time since install and I have no oil pressure ....I tapped oil pressure gauge from right on top of the filter housing .....crank it over no oil pressure none zip zero ...took the line of by filter no oil coming out ....just removed the filter adapter to check gasket ....seems ok ...figured i would crank it and see if i would get oil to come out ....zip zero ...whats going on ....do i need to prime the pump will i only get pressure when I start it up ....don`t want to start it with no pressure ....going nuts have months into this install and now this .....HELP !!! PLEASE....THANKS
