OK been working on some stuff on the DeScrambler. My most recent project has been installing Air Bags on the Rear Suspension.
The reason for needing them was two fold.
First; I needed to be able to adjust the ride height of the Jeep when loaded.
Second; I wanted to take some of the top heavy/roll out of it. It was kind of floppy when going around corners or off camber turns.
Well after my Test Drive this afternoon I have succeeded on both. With 20 psi in each Airbag, (plumbed independent of each other) it goes around corners very smoothly now, and the rear end is up just about an inch to bring the Jeep level.
Kind of self explanatory how they are assembled. The top bracket is bolted to the frame rail and the lower is bolted to the rear of the top plate of the Spring Perch.
Important thing here is that they work, and the difference in the ride was noticeable within the first 1/4 mile!
Next Project is the Ring addition to the Vibration Damper.
Randy
Randy
