High fuel consumption
310 Views 3 Replies 4 Participants Last post by  DoAll
Need some advice on what to adjust/test to reduce fuel usage.
I am using around 16 litres per 100kms driving sedately, I’m becoming a old man.
I only get black smoke on hard acceleration before boost comes on, once boost builds its clean.
I have only had the car on the road for a few months after installing a 4bd1t with a compound setup [HE221 and a WH1C] and a 4l80e auto ,I am running AT 225/95/16 = 33” tyres.
The full load screw has been backed off, control rack bolt removed there is no boost or altitude compensator is fitted, I am happy with the performance of my 2800kg 4x4.
Using a MADMAN EMS 3 gauge for all the pressure and temperatures ,all the sensors have been calibrated with recently calibrated test gear.
HE221 set at 35 psi
WH1C has a 12psi spring
Tial waste gate opens at 21psi
Air regulator is fully open
rpmhe221/intake manifold psiwh1c psiexhaust manifold psiEGT pre turbo oil psi speed kms
idle 900000240180
120020126018
140050127022
1600110529028
1800180831035
2000202133303620
22002781845043
24003112215104740
26003514246005360
28003416236705775
1720124 Freeway driving 360100
1850144Freeway driving 380110
Font Parallel Rectangle Schematic Diagram
Any suggestions would be greatly appreciated.
See less See more
Reactions: 1
1 - 4 of 4 Posts
Gearing looks good, you're pushing a bit of weight around. How does your aerodynamic profile look?
I'd expect a 2.8 ton 4wd with 4sp auto in best case to be using around 12 litres/100km. If you throw in chunkier tyres and worse aerodynamics you're probably not going to be much better than 14 litres/100km.
I'm half a ton lighter, manual, probably better aerodynamics and get 10litres/100km on a road-trip. 12 litres/100km general driving.
For comparison. A guy I knew had a 2.4 petrol Toyota Previa which was burning 14 litres/100km.
Reactions: 1
I’d love to try a 225/95/16 tire. Certainly not something we see here in the ‘States but I’d wager they are a great tire for fuel economy.
2
Fuel economy is one of the reasons I got these tyres price was another ,they are off a brand new Toyota troopy ,OEM troopy tyre is 225/95/16 in Australia , most people are putting alloy rims with fat tyres.
See less See more
Reactions: 2
1 - 4 of 4 Posts
