Easy to assemble with no welding required. Made from threaded rod (M12 x 1.5mm pitch) with matching lug nuts, jam nut, a 3/8 inch flat washer and a 1" x 4" threaded conduit nipple. With the exception of the threaded rod which came from McMaster Carr (catalog number 98861A545) all the items were locally available. The threaded rod comes in the 300 mm length which is about 12 inches. I used the longer shoulder style lug nuts because of their longer length.
The first picture shows the components assembled. The second photo shows how the end of the rod threads onto the injector. Of course this is without the conduit nipple as a spacer in place. I ran them down finger tight and then backed off a half turn to prevent the possibility of damaging the tip of the injector.
