Hey All,
I'm in the process of planning and saving to drop a 4bt into my 1995 F150. I think I've got everything fiqured out except for two things: (1) Will a 4bt fit under the stock hood, or will I need to run a cowled hood for it to fit? (2) I'm planning on using the stock in-tank fuel pump for a lift pump, so my understanding is that the fuel pressure will need to be stepped down before the injector pump. Should I use a fuel pressure regulator or set up a return line from the injector pump back to fuel tank. Thanks for the advice, guys!!
