1 - 3 of 3 Posts
i was wondering the horsepower ratings you can get out of a 6bt without an intercooler? I know juicing up the pump can be really risky when it comes to not having an intercooler or proper cool air flow however i will have a pyrometer connected to the downpipe. I also realize that the temps can be 300 degrees different from manifold to downpipe, is this correct thanks for the input
Not having a I/C your temp will be high if you turn up the pump,your gauge will tell you how far you can go.The probe in the down pipe will be more than 300* off ,best to have it before the turbo.
Scott
You can get almost 300 flywheel hp out of one. Egt's would be out of sight. Should be ok for 10-20sec bursts. Cummins did a marine non IC engine at 210 or 220hp. The 4bt marine non IC went 150hp.
1 - 3 of 3 Posts
