1 - 9 of 9 Posts
Isuzu reliability tester
I am curious about the p-pumped 4bt. I have heard of them but never seen them. Are they worth finding? I would assume there is a performance advantage over a ve pump, is this true? What about mpg compared to a ve pump at, oh say 300 flywheel hp?
What year and kind of vehicle did they come in?
mine is in a 95 oshkosh stepvan.
former fedex ground and RPS truck.
I reckon it gets 15-16 mpgs, pushing a 9 thousand pound cracker box down the road.
stock.
isnt that about the same mpg's the VE pumped engines get in the bread vans? Do all the 95 and newer 4bt's come with a p pump?
The maintenance guy at Frito-Lay where I got my truck said that the P pump motors have more power, but the pumps don't hold up nearly as good as the VE pump. He thinks it's because of ULSD. A diesel specialist told me that the P pump gives better emissions than the VE because of a sharper injection event. I'll stick to my VE for reliability.
that's really surprising, i would expect the other way around. The P pumps are supposed to be more robust because they are lubricated with engine oil, not with fuel like the VE's. i would expect the VE's to be more succeptable to lack of lubrication from ULSD than the P pumps. My personal guess would be that if there is a lack of reliability, it is something other than ULSD.
I am curious about the p-pumped 4bt. What year and kind of vehicle did they come in?
CPL 1839 Inline Pump, 130 HP
1994-98 Oshkosh & Freightliner, “M” Line (MT-35 Freightliner)
This engine has a front sump oil pan. For most conversions, you'll have to rotate the pan 180* and purchase a new oil pump pickup.
p pump
the P Pump has more performance benefits over the rotary(VE) if you are only looking for mpg then there is no real reason to go to a P, dependability they both have been around a long time...Rotay will have limited potential from a total performance...The P pump engines are out there and even more so in the Industrial area. the key is finding a good ADS shop that can build a really good pump, changing some bolt on items will help but not anything like a good ADS shop.........Sorry this is just my thoughts and I'm sure there are alot of guys out there that know more than I do.....
The P pump is the P-7100 correct? I am fairly new to the 4bt's, just trying to learn. If the VE pump is more reliable, that's what I'm after.
The P pump (P7100) is known as the "Million Mile Pump" and it's reliability is unquestionable at this point. The VE is no slouch in the reliability department either. For most applications, I would go with the VE pump. VE pumped 4BT's are cheap and available, compared to P pumped 4BT's. Also, you can turn 'em up for free to satisfy most applications.:)
Bob B.
1 - 9 of 9 Posts
