I have figured out the CPL # 0858 with help from here. But I do believe that the serial is on the info plate correct? Mine is gone how else would I figure the serial?
sorry for the late replyI may be able to help you some. CPL 0858 was a very common one used in road vehicles. There were different specs on certain parts depending on application. One version came on the Ford E350 vans. Generally, you will see it with a top mounted turbo and a belt driven vacuum pump. It would have a transmission adapter with a small block Ford bolt pattern and a flywheel for a manual transmission. The GM units came in 2 designed. Both those version will usually have the turbo mounted in a low rear position. That turbo tend to have a different sized turbine housing. Normally, no vacuum pump on those. The transmission adapter is a standard GM on both versions. The difference is one come with parts for the TH475 that was found in GM P30 van. Maybe 10% of the vans had a manual transmission and those have a GM flywheel. Have you got a photo of your engine? If you can tell me which engine style you have I have ESN's for them. If the data plate is missing from the front gear housing, the engine serial number (ESN) is sometimes stamped on the rear of the block just below the head. This happens only when Cummins has rebuilt the engine. You mention the CPL and the injection pump can give a clue to that number. CPL 0858 changed injection pumps a lot over the years when it was produced. There were about 8 or 10 different numbers for that CPL.
If this is to me, just another day! long story. So far AgKits is letting me buy parts based on the piston #7163 and the connecting rod # 3901566. It has a VE pump but the numbers are currently smashed against the dog house due to having to lift the engine high enough to pull the pan to pull #4 piston that melted leaving aluminum all over the head and top of the cylinder.That number on the engine won't help. Which injection pump do you have? From that there should be an ID plate on the pump that has a series of numbers. From that we can probably narrow down the CPL of the engine and find you a serial number you could use to buy parts. If the engine has been rebuilt you would need to measure rod and crank journals to be sure what size bearings are needed.
Here's a photo of a VE pump where you can see the ID plate.
Here is one type of ID plate.
You see the number there 394 6371. That is a Cummins part number 3946371. Gives you something to look for.
Good Afternoon,Assuming this is a road engine, the only CPL's with piston 7163 were 0857 and 0858. CPL 0858 was one of the most common ones. CPL 0857 was one with the aftercooler and it's not common. If you can get a look at the injection pump I might can narrow it down. CPL 0858 used a number of injection pumps. Ones that I know of were 3911242, 3914924, and 3917530. Also, is your turbo mounted in a low rear position or a top center one?
Hey char1355, Thank you.Then you have a CPL 0858 which was one of the most common 4bt engines. If the engine serial number isn't stamped on the back of the block just below the head there is no way to know your specific serial number. If there were a number there it would mean Cummins had rebuilt the engine at some point in time. Here is a serial number 44541365 you might use to look up parts. It has injection pump 3917530 and came in a Chevy P30 van with automatic transmission.
It is supposed to be a 400 but I already have a 700 ready to go when I can get the Van in my shop just going to need a driveshaft made up for it. I can attest to the pretty much lack of brakes without fluid not just hard. if I wasn't on flat ground when the engine died I didn't really know if I could have got it stopped. When I test drove it I just assumed it was manual steering and brakes. I also assumed it would have water in the brand new radiator, he had drove it to meet me so wasn't about to open it to check. No tach so I don't know what the engine was turning but 55 was a bit too tightly wound. I am in Seattle so if it can do 30 on the freeway 80% of the time it will work as a local plumbing rig, the 700 will just give me a bit more.Unless someone has changed it your transmission is not a TH400. It's a TH475 which is a heavy duty version of the TH400. Power brakes on those vans were usually hydroboost running off the power steering pump. If you lose power steering you lose brakes too. Makes for a fun ride on a steep down hill. LOL. And 50 MPH is pretty much top speed with 3 cylinders or 4 cylinders. Those vans weren't designed as highway cruisers.
