My daily driver Superduty has a VE 12 valve. It runs an HE351, Colt stage 3 cam and 5x.013 155 degree injectors in tapered open bowl pistons. I would put it around 350HP and I feel it's very conservatively fueled. It does not smoke at all. I have base timing at 16 degrees BTDC. It spools the HE351 well here and pulls like a freight train to 3500. I have grossed around 20K towing with it a few times and it does well.VE injection pumps in general aren't known for extreme high performance. We have guys running a standard VE pump on 300 HP 4bts. That would translate to 450 HP on a 6bt. So I'd say that is very possible. Not sure what mods Hungry Diesel has done to the pump. To run that power level you'd need at least 5x.012 injectors. That's about as big as most VE's like. One thing I noticed in their photos is the pump has the wax motor KSB unit. That part advances pump timing to help with warm up. Mainly a smog control item. The reason I mention it is because it needs to be functional or the timing is always advanced. If you engine has the sensor and wiring for that style then no problem. Those parts are expensive, especially the wiring harness. That style KSB was only used about 2 years and changed to a solenoid type which is much better. The wax motor type has to be functional to turn it off. The solenoid type has to be functional to turn it on so if you don't hook it up there's no problem. At the power level you're thinking on you probably should think on twin turbos.
I am running 5x12 sac 155's now with non inter cooled pistons, inter cooled aftermarket stock head, HE351, denny stage 2 pin and turned almost all the way up, stock cam, I do not think I'm much over 300hp but have never had it on a dyno, I do not have an intercooler and I think it is holding me back a lotMark, you say a 5x.016. Never heard of a VE being able to run that big of an injector. 5x.012 should be able to do 450 HP on a 6bt it they'll so 300 HP on a 4bt or am I missing something. That's 75 HP per cylinder.
Are tapered open bowl pistons same as the non-intercooled ones?My daily driver Superduty has a VE 12 valve. It runs an HE351, Colt stage 3 cam and 5x.013 155 degree injectors in tapered open bowl pistons. I would put it around 350HP and I feel it's very conservatively fueled. It does not smoke at all. I have base timing at 16 degrees BTDC. It spools the HE351 well here and pulls like a freight train to 3500. I have grossed around 20K towing with it a few times and it does well.
I don't know anyone running the Hungry pump. The price seems good if it is a blueprinted pump built with a new camplate, rollers and distributor head.
I am told VE's do very well with extremely large injectors, but have never run bigger than 5x.013's.
those look exactly like the stock non-intercooled pistons, I believe very similar to marine ones too, I ask because he is running 155 injectors like me, when I had 145's with these pistons it ran like garbageI believe he's talking about these, they are what I put in my '88 4BT with compounds.
How much boost are you running and at what rpm?Large bowl use 155* these have been machined in a lathe with ~ .020" taper in the area from the rings up this is to enable standard piston to wall clearance on a majority of the piston while maintaining the extra needed where they could expand enough to score the cylinder wall when running high boost/chamber pressure ratios. With them and larger cooling nozzles you have a bigger margin when running things harder and longer at higher power levels.
