I have racked my brain for the last two weeks searching to decide which turbo to use on my build. there is a lot of info out there and a lot of debate. I am hoping for some guidance on what will be best for my build and situation.
I have a wh1c off of a 94 dodge, and a Hy35 off of an early 2004 dodge. I am looking for info on which would be a better turbo to use on my build. My budget is to the point that I will have to put one of these on and get the truck on the road, and later decide if i want to buy a new turbo that may be a better fit.
I have an unknown cpl 4bt, ve pump with aneroid supposedly from a step van. I have rebuilt the engine with head studs and o-rings to allow for future growth.
Engine Mods:
THD fuel Pin
3200 spring
Colt Cam stage 3 camshaft
DDP Stage 3 injectors
Steed Speed exhaust manifold
Frostbite intercooler 30"x 13"x 3", 2.5" in/out (35 psi max constant)
Pump fueling, and timing will be adjusted as necessary.
This will go in an 85 K5 Blazer
47rh transmission, dodge 208 t-case
35" tires, 3.42 gears 80mph @ 1,800 rpm. 60mph @1,360rpm
The truck will be an on road weekend vehicle for my wife, and a backup driver for me. No towing.
My wife will just drive it around town, and I will run 80 on the interstate to work and back.
My thoughts so far:
HX35 may surge in lower boost situations, 12 cm housing take longer to boost, but "better top end"
Hy35 will spool quicker than HX35, but "limited top end"
I am not sure how limited the top end would be, I would plan on keeping the wastegate and modify if necessary.
There is alot of talk about the HX30, and I bet it would spool quick, but I would also wonder if it would be a big choking point in the higher rpms. I will have a very hard time buying a new turbo without having the truck on the road first to understand how it will drive with one of the turbos that I have.
I am not afraid of moderate smoke or 1250 plus egts on the short term as you are accelerating, but would not want flat highway speed at 1200 deg. With the auto trans I am less worried about instant spooling, but don't want as much lag as my first gen Cummins 5 speed with the 21 cm h1c.
I am leaning towards the HY35 with the 9cm housing for quicker spool, from research here it seemed like the hot item, and then fell out for the HX30.
Between these two choices, which would be a better fit? How do you think drivability will be?
Also if I am way out of line with this combo please help me understand how.
Engine Mods:
THD fuel Pin
3200 spring
My thoughts so far:
