1 - 3 of 3 Posts
I found a foreign object on Cummins 4bt wheels. before that the bendix of starter dynamo was broken and after it was repaired and I tried it, and I found a foreign object on the wheels like in the picture. From which component the object and what affected?
127822
127823
I found a foreign object on Cummins 4bt wheels. before that the bendix of starter dynamo was broken and after it was repaired and I tried it, and I found a foreign object on the wheels like in the picture. From which component the object and what affected? View attachment 127822 View attachment 127823
[/QUOTE/
Are you referring to the flywheel? -looks your pilot bearing came apart and needs replacing. Not a big deal but will require pulling the transmission or what ever the engine is connected to.
Or are you referring to the front timing gears? -dunno
Hope that helps,
Glendon
Sorry your wording is off a little, do not understand the "wheels" bit.
Those are needle bearings. What was the problem with the starter motor?
1 - 3 of 3 Posts
