1 - 9 of 9 Posts
I was looking into putting a 4bt in my gmc 3/4 ton pick up and i was needing to know if it should pull my truck good or not. Also I wanted to know how much it would cost to git it going and what I would need. If any one can help me out I would sure appreciate it. Thanks
Need more info here chief, the questions are very vague. Engine costs range from the Low $1000's up to $5500 for a fully re-furbed unit.
What exactly are you going to do with it? Tow? Offroad? Daily Driver only?
Is it 2wd? 4wd? Manual? Auto?
Well, you've got a pretty heavy rig already, I'd say in the neighborhood of 5-5500lbs. If you're going to tow a lot, you might consider a 6BT as they're they cost pretty much the same. A 4BT should be ok if you're pulling a light load. For a lot of towing, especially in the hills, the 6BT would be better suited. Check out the FAQ thread for a lot of good tips on transmissions. \
While your stock SM465 would work with the 4/6BT the gear ratios aren't the perfect setup for the diesel's RPM range (towing especially). Something like the NV4500/FordZF 6 speed might be a better choice. Do some reading, there are several FS chevy conversions on here, some with 4's & 6 cyls.
Ok thank you for your help, but I have and nv4500 transmission will that bolt up to the 4bt or do I need and adapter plate? Also what is the price tag on making the 4bt twin turbo?
To mount any transmission to the B series Cummins you need a engine adapter
Gm Nv4500 96 or newer will bolt up to a Dodge bellhousing 94-2001
Dodge Nv 4500 94-2001
Engine adapter dodge auto or manual 94-2001
or use a Gm nv4500 with the P-3o adapter .
Scott
I am going to do all of what you said plus i want good fuel mileage. It is 4x4 with a manual
What year is your Chevy? Was it already set up with the NV 4500?
Bob B.
a twin setup would be, umm trial and error. that i know of only one guy on here has accually done it, but it all depends on your turbos. i would go with the 6bt for your truck. my father has a 98 ram 24v and with a supechips programmer he gets about 19.5 in the city. just my opinion.
Airborne,
The chevy adapter plate is very expensive. If you run Dodge stuff, buy an adapter plate off car-part.com. Get them for about $125.00 which is much cheaper than on ebay.
1 - 9 of 9 Posts
