They give you a min amount of shims in the test spec then the tech can fine tune the advance from there. What is your pump number I can tell you what spring you have. That thread was right on though it does Increase Nox emission's but youll get better fuel mileage (more time for the burn) and better throttle response. You can go to far though and youll get a ping.
My pump number is 460 426 114. Can you provide the spring part numbers, the colored springs? And can you fine tune timing of the pump as easy as backing off a bit if you have ping?
I gotta tell ya, if you can hear a ping while one of these is running, your hearing is much better than mine...
To reseal the injector pump? In the last year I bought one generic seal kit off ebay and I bought one recently at the local Authorized Bosch diesel pump shop. The Bosch p/n is DGK121 it cost me $19 and is definately a better kit.
