1 - 6 of 6 Posts
Okay, i'm finishing up my 4bt project and moving on to my 69 CC f350 with a 4x4 47RH and a 241 DHD. I want to build it right. I'm figuring for the money it would take to go to the 4r100 or 5r110 i can get the 47RH done right and save money.
If you've got experience with building up a 47Rh to make it stand up to towing it would be great for you to share that here. I will be towing camper/boat/ and occasional 15K gooseneck trailer.
I'm not going to be more that 250 HP and I plan to use one of Phil's super single disc torque convertors with a slightly lowered stall.
He suggested a good valve body to get pressures up a bit.
Any recommendations on who to use/or what kit to use for a good VB rebuild?
As far as OD and LU i'm working on a stand alone controller apart from the PCM and pressure switches to control their function- i'll post up more soon on that!
I don't think i need a billet shaft or anything like that, but if you have suggestions on how to's or maybe even which kit to use, please post away.
Lastly, many times you get what you pay for, but i don't want to overspend on something that doesn't have a good return!!!
In my opinion, the major weak link is the torque converter in a 47rh. Good aftermarket converters are 800-1200 bucks, I would recommend 12-1400 stall, I don't know what brand is better. Also a shift kit wouldn't hurt, they're about 300 where I've checked. Then the biggest cooler you can fit. After that it should do what you need and stay reasonably reliable.
I wouldn't bother with any billet shafts with the 4bt unless you really want to shift WOT with the tc locked... IMO, you're on the right track with a tighter single and a better valve body with more line pressure.
Temp sending unit in the hot line to the trans cooler never hurt anything either ;)
Depends on how far you take it apart. I Always replace the OD bearings and plate. I love the TFOD-JR shift kit but transgo says go with the diesel kit.
If you want to go HD then strait cut gears in the OD. after that then you can start using 48re stuff but I wouldn't consider it nessesary.
Go low stall & billet on the converter. But remember that a 1800stall for a 6bt will stall at about 1600-1700 behind a 4bt. multi-disk isn't a big deal unless you plan on towing huge loads.
Remember they were designed to hold up to a 6bt.
The best thing you can do is to actually service it. drop the pan and adjust the bands every 30k or so.
If you want any parts at a better price PM me and I'll get you some pricing.
Discussion Starter · #6 ·
Thanks Ryan I will pm you later.
1 - 6 of 6 Posts
