I'm not sure I understand what you're saying, Carl, but that sounds normal [if you said what I think you said ha haha] That is, it's normal to see some air bubbles and bubbly fuel squirting out when you bleed the injectors. Let it bleed until clear fuel with no bubbles comes out of all injectors and you'll be good to go.
If it's leaking bubbly fuel with injectors tightened back down then you do have a problem. That would indicate a problem with o-rings or something at injector.
I installed a length of clear vinyl tubing just before the fuel filter inlet so I could monitor fuel delivered from tank, to quickly check for air leaks. Installed it a few months ago and will probably leave it permanently if diesel doesn't break down the vinyl tubing.
