I just used antiseize on the outside of the body and fit the square section seal rings they use. They press into to top of the hold down nut.
Thanks Charlie, attaching a couple photos of the injecto. As you can see it does not have the Or ring so that may one of my problems.It's a bit odd that the injector hold down nut does not show anywhere on the parts list for the engine. Shows a breakdown view of the injector but that part doesn't show as separate. The hold down nut is a Bosch part 2433462014. However, the sealing O ring does show in the Cummins parts list as 3909356. You can find those priced from about $1 each to $3.66 each at Cummins.
