Well I contacted Billy Williams at Diesel Care regarding my stock injectors, Cummins p/n 3912468. These are the 'mystery injectors' I posted about before. Quoting his e-mail reply:
"The injector you have mentioned 14m top 7mm tip is the same as the 275 300HP injectors [understand that these are 6BT HP ratings, and would not be the same on a 4BT] in the late model Dodges, so both could work for your application."
So some of you might want to research that further and see about these injectors for your build.
JimmieD
JimmieD
