Ok, I ran my stock injectors for a while before I swaped in the PODs. I first ran the PODs with everything else on my 4b stock. I noticed high EGTs and lots of smoke, it just needed a little tuning. Timing helps a lot, PODs like timing. Also with your turbo and intercooler you should be fine. I now have a HY35 and a fairly large intercooler on mine and it is awsome! My EGTs are great, boost is at 35 psi, has plenty of power at all speeds, and gets a 5-6 mpg increase over stock. So in my opinion it was money very well spent.
Injectors teamed up with a little timing, more air, and some pump tweaks will really wake an ol' 4b up.
You'll also see some way better boost numbers from what you are seeing now and you will be able to "roll the coal when wanted"
