1 - 3 of 3 Posts
Hello,
I see people "cutting down" intercoolers. In which way can this be done, bringing the tanks together or in terms of height?
Thank you.
Mikel
Hello,
Thank you.
Mikel
bringing the height down if i understand your question correctly. It requires welding AL, if you don't have a problem doing AL welding, it should be doable. Essentially you cut intercooler to the right size and recap the top and bottom.
Whenn cutting off the top or bottom all is needed to cap off the end tanks where the rows were cut.If you cut off the end tanks your taking the chance of cutting off the core bad air flow.
CrewCab59
1 - 3 of 3 Posts
