OK, the original thread was "QSB 4.5 without the electronics"
I have a 4.5L front gear train, 8 valve head, mechanical injection.
Block is back, bored and honed .020. Pistons installed. I just degreed the stock camshaft.
At .050 int. dur 100.5 degrees, lift 254 Exh 245 degrees and 264 lift.
I have been searching for weeks to find a cam that will give better performance. I believe a 3.9 cam will fit, they appear identical. Does anyone know where I can get a better cam? Not a wild build, just something to give better road drivability.
I found a place in Canada that will regrind my current one, but do not know what specs to give them. Any help would be appreciated. Char, any ideas?
Oh, BTW, the cam lock pin engaged just shy of 2 degrees before TDC. I set it to actual TDC and loosened the two bolts. It moves around a little. Locked it in at exactly TDC and retightened the bolts. Also piston protrusion is .019" above the deck.
