Bumping again.. You ever get your engine to start? My engine is missing the whole fuel filter assembly and due to packaging I am running an FASS pump back near the tank on my project. I'm running a nice long line up to the ECM, then from ECM to the "lift pump" on the front of the CP3, and then to the high side of the CP3 and then from the out side of the CP3 back to the tank again. All -08 and -06 lines.
The free open line is going to come from the fuel temp sensor / computer and then feed back to the inlet of the lift pump, then the jump line goes from lift pump to the CP3 high pressure side and then the top fitting is the return.. correct?
