Yep, my standard tachometer wouldn't work with my 4bt as well. I bought a Autometer diesel tach and installed it. It has a pickup that attaches to the alternator, as viewed in the pic below. They come in various sizes and work good. No complaints.
Do you have any pictures or maybe some more in depth instructions on how you did that? For example, I’m not sure what you mean by the notches you made, any more details is appreciated for a novice like myself that’s learning as he goes.I have had success making the stock tac work with diesels, I put notches in the crank pulley and mounted an ABS sensor to read pulses. 2 notches for a 4cyl, 3 for a 6 and 4 for a v8. Two wire hook-up one to 12v and the other to the lead that went to the coil.
By lead that "went to the coil" do you mean the tachometer connection from the coil? So 12v in to pickup then out to tach?I have had success making the stock tac work with diesels, I put notches in the crank pulley and mounted an ABS sensor to read pulses. 2 notches for a 4cyl, 3 for a 6 and 4 for a v8. Two wire hook-up one to 12v and the other to the lead that went to the coil.
The notches need to be deep enough and wide enough, 1/4 x1/4 or so to cause a dead spot creating a pulse. If the gasser motor taken out was a 4cyl then 2 notches and so on. The ABS (hall sensor) I used was only a 2 wire, it self grounded, one wire to 12v key on and the other to the tach lead that used to go to the ignition coil.Do you have any pictures or maybe some more in depth instructions on how you did that? For example, I’m not sure what you mean by the notches you made, any more details is appreciated for a novice like myself that’s learning as he goes.
I have had success using the dakota digital tachometer converter with the stock CJ7 tach.Need some help. I’ve got a 1987 4BT in my 84 CJ7 which came factory with a tach, that I’d like to keep. Will I need a new tach? If not how do I wire this one up? My mechanic mentioned something about Autometer selling something to attach to the alternator but he wasn’t very sure. Any help is appreciated.
