I just found this site. I want to put the 4bt in a 1997 TJ Jeep. It has a 4.0 inline six and a AX-15 5 speed. Is there a conversion kit to bolt the 4bt to the existing drive train. Stock power should not be to much IMO. I want to bulid one as a trial run first, then build a twin turbo intercooled with head studs injectors, pump work etc. and a NV 4500 with dana 60's front and rear, but that is going to be a year before I go all out. any info and pictures would be great.. Also I might build an automatic jeep second go round. Will a 47rh bolt up to a 4bt???
