So i have alot of questions so im just gonna jump into it. I'm installing a 4bt 3.9 into my 91 YJ. I stupidly jumped on the first 4bt I came across that I could afford. So it has the Lucas injector pump. Which I'll obviously change out. From what I've learned from the research I've done so far I'm gonna go with the VE-pump. Can I use the same injector pump drive gear?
On another note. I ordered the rebuild kit that comes with sleeves, pistons ,valves the whole sha-bam. And I received a message from the seller, asking the measurement of the combustion chamber. So what I have is the 45mm. can I go up to the 50mm since I'm running a bigger pump and planning on maybe stage two injectors?(....waiting to be bashed on that comment.....)but keep the crank and for now the cam. I'm also thinking of using the HX30 turbo(....waiting for yelling and cussing...) and I'm wanting to get the bell housing adapter to be able to run the ax15 transmission along with the rest of my drive-terrain.
So this is all on paper right now..well kinda.
I have the motor taken apart down to the block and crank, cam and gearing is all still bolted up. So please guide me my fellow fabricators, mechanics and guys who know more than I do.
