I just took my first test drive with my newly rebuilt p pump 4bt. It ran fine for a while then seemed like the idle was creeping up. The rpm started going up like crazy and there was a cloud of steam. I got out of traffic, checked for stuck throttle and restarted. Immediately went to high rpm. I limped home by starting and coasting. One of the frost plugs has blown out and the coolant is gone. The oil is full and clear. The whole experience was a bit too frenzied to check gauges. I had the pump adjusted while it was apart and set the timing to 16 degrees. The turbo is a brand new hx30w. I ground the fuel plate to a 10 profile and slid it forward but haven't adjusted the star wheel. Any advice?
Ian
Ian
