1 - 3 of 3 Posts
Need part number for injector for
Kubota el300-E E70-956076
I am told this came out of a tractor
Any help would be appreciated
Thank you
I found a couple reference numbers for the EL300. One is Denso or Bosch part 0934000800 or 093400-0800 and the other is ND-DN4SD24ND80. Seems the same injector was also in some Toyota engines.
I have a Bobcat S70 with a Kubota D1005 that had a cracked head. I replaced the head, all the gaskets, and injectors. Now, when you start it up, it runs very rough and blows excessive white smoke. The engine smooths out after about 1 minute. However, it continues to blow a lot of white smoke. What should I be looking for now?
192.168.100.1 192.168.1.1 jpg to pdf
1 - 3 of 3 Posts
