I am stuck in new orleans, needing my injecter pump rebuilt or replaced.
The truck runs fine, it just leaks fuel somewhere around the injector pump onto the outside of the engine.
I didnot have a leak until I found that my lift pump was not working, for how long, I do not know. I do know that the injector pumps self destruct when they run for a while with a loser for a lift pump.
This truck has possibly made 2 round trips from Ohio, to New orleans with a bad lift pump.
On the highway once and a while at full throttle it would feel like it was running out of fuel until I let off the throttle, then it would pick up where it left off. So I figure it has been weak at the minimum for the duration of the trips.
So, I figure it has given up the ghost.
Whadda ya do in my sitiation! I am not even sure where it is leaking from yet. It started leaking the day I put the new lift pump in..
Are they pricy to rebuild or replace? Is there another pump I can swap it out for that is abundant?
Any more free help I can get will be put to use here in NOLA!!
